| I did a compression test on my motor the other day. My results are the following. Cyl 1: 120pis Cyl 2: 140psi Cyl 3: 165psi Cyl 4: 155psi Cyl 5: 135psi Cyl 6: 150psi I know some of those numbers ARENT great, especially since I wanted to see if I could boost my NA motor. I haven't done a wet test yet but just in regard to the lower numbers, would it be worth rebuilding to hold boost? or just buying a TT motor with all the other parts id need to run it?
